Clutch Torque Specs..Primary and Secondary.
T
TheCirque
Can someone remind me of the torque specs for the primary and secondary mounting bolts on my Gen II?
Thanks.
Not sure about the Gen II, but for the IQ's and maybe the edges: primary 96 lbs, secondary 12 lbs w/ blue loc-tite.
don't mean to highjack your thread but I was wondering what the torque is on the edge 800 for the primary?
Someone posted it the other day on another thread as 96, sorry for the bad info. Of course I can't find that post now.
Found the old post with 96 lbs for 900's
Found this from Mountanhourse
900 Iq Primary Install And Torque Procedures
I've got a lot of Pm's on this from an old post.
Here is the install procedures on the 900's primarys... note that the old spec of 50 ft lbs is not correct for these engines... before you ask, I do not know about the new dragons and 700... The proper torque spec is 96 ft/lbs.
Some tips: NEVER use an impact to remove or install the primary. Always use a proper clutch holding tool to remove the bolt and tighten, buy hand-wrench, the removal tool.
This is not a wives tale... the snouts on the cranks can develop stress cracks that can cause big problems later down the line.... Don't listen to those that say "I've been using an impact for years on the clutches without a problem.....". Just not a good idea given the cost of a crank and the relative ease of taking a few extra moments to do it correctly.
For Edge 800 the 04 service manual calls for:
40-45 ft lbs for large ID 3/4" shaft primary
50 ft lbs for small ID 7/16" shaft primary
17 ft lbs for secondary
