M
mtn mike on boost
am I the only one having trouble getting the front retainer hooked? what a chore, its super tight on mine and you cant see **** with the oil reservoir there. tricks??
Yes I find if you pull back on the front then pull left and then pull up it works not to bad.My dealer guy told me that when removing and putting back together if you take left hand and push the front of cover back a little it makes much better. But still a PITA.
Yes it does. Stops the panel from rubbing the clutches when on it's side.why not just remove the whole thing? i mean, other than the obvious risk of doing some damage if you blow a belt. does it really need to be there?
Totally sucks in my opinion. Hard to get off and even harder to get back on as the slot does not line up well in the front and you can't see the hole either.
If we did not need it to keep a grenaded belt from blowing the oil bottle to kingdom come....id do something different, may still...
Thanks Norona!
You should start a thread on these little mods.
