I hope it works!!! Last thing I want to see is any rider having clutch issues...Not sure how the Ti will hold up is all...could be made in hardened steel for longevity..not a huge difference being it is in the center....Great idea!
This should address either issue.It would be interesting to see what the split is on 9R failures. Feels like I was seeing the bolt come out more than I was seeing it break but maybe I'm making that up
The source is all the same. Basically if u stretch the bolt a little before failure it would walk itself out fairly quickly from vibration. No matter what having a spider not surely attached to the movable sheave is the issue and this does target a quality solution.It would be interesting to see what the split is on 9R failures. Feels like I was seeing the bolt come out more than I was seeing it break but maybe I'm making that up
When Polaris first announced the P-22, I was just as excited as I was of listening to Metallica in the 80’s. Then I saw Lars play in person in ‘89 and was disgusted with his performance and in myself for believing he was a good drummer. Same exact thing happened with the P-22.
The only fix for the P-22 is throwing it in the trash can. Same for Metallica.
This takes the cake on dumbest analogy I’ve heard yet on this forum…
The only issue I have had with going to a p85 on my 9r's is clutch weight bushings only last 3-400 miles. Not much longer on my boost either. That's one of the advantages the p22 does have.I appreciate the after market community coming up with solutions to fix oem problems and I’m sure this is a quality product but even if it makes the P22 bulletproof why take a step back wards in clutching? Is it because we don’t want to adjust belt deflection? I know I’ve been beating a dead horse but I’m so over the P22
