F
I have a recently purchased /low mile 2016 Limited Sno Pro with a C-Tec 600. Sled has 900 miles on it. I basically like the sled but the engine is as poor running an Arctic Cat engine as I have ever had. It has unstable idle. The engine also boggs and "stumbles" through most of the RPM range. Mostly when you try to hold a steady RPM but it seems the worst at around 6500-6800 RPM. It is really annoying. Has Cat addressed this with a service bulletin or recall? Others are having a the same issue. SLP has an intake temp sensor relocation kit ($40 for a cable extension) that they say fixes the problem on the C-Tec 800 but will this help the 600 also. Is there a fix for this that anyone has tried? Suggestions?
