W
wheelierida
Can I measure the bushings in the primary with a caliper? or is it nessecary to use a bore gauge to get correct #'s? The manual says to replace the sliding sheave if the bushing is bad...is that neccesary?
On the governor cup there is 2 tamper proof torque screws. It looks like there should be three but the spot where the other would go doesn't have any threads in it. My cousins only has one and the two other holes arn't threaded either. Are they for balancing or what??
On another note.... don't use cotter pins from the hardware store!! they seized in my weights. I had to cut the arms to salvage my rollers. I'm pretty sure I wont be able to save my weights either.
Thanks again guys!
Thanks again guys!
