C
20 miles and 2 hrs into trip, water temp was 105F.
Stopped for 30 seconds, started it and took off at a 15 mph clip. 20 feet later it beeped and flashed "rev limit" then immediate power loss and I slapped the killswitch.
Locked up with maybe 10° rock back and forth. Took out the motor today and found a broken oil line which I guessed was the problem on the way home.
also, all i needed was a new rod and bearing. why the HELL cant you buy a rod and bearing instead of an $1800 crank? seems like swindle/fraud/etc.
How did this little section catch fire UNDER the motor? Y-pipe line to water pump was completely fine.
