Best spark plugs to run in RMK 700???
I
What is the best spark plug for a 2000 RMK 700? I just like to know if it would make a difference than walking into an oreilly and buying a "no-name" brand of spark plugs
NGK BR8ES
Careful with this advice. This isn't even the correct style of plug. The electrode is flush with the bottom threaded portion of the plug... This is wrong, it doesn't even go far enough down into the cylinder like the stock plug. This is the old style plug that the fugi engines use. Second of all this plug is too hot and can cause detonation.
If you were to use an NGK plug youd have to use a BPR9ES.
Why would you not run what it came with?
If the sled is fouling plugs, it is not the plugs fault, it is your fault.
