Best Ski
Feb 28, 2011
14
1
3
So I've hunted the forum for a bit but lots of dead conversations. What's the best ski right now? CMX's ski looks a lot like the Yeti but has no dimensions. I've ridden the ARO and Backcountry and really neither seem to be wide enough and have enough float. I've not ridden the Yeti in real powder to actually try it. And have never seen a Camso or CMX.
Thoughts? Skis are changing and I need a new one.
needpowder
1,290
355
83
45
Utah
I think the Aro ski is the widest but I’m not sure about the CMX as I have not seen the new one. It is possible you’re set up with a little too much ski pressure? I feel like the Aro ski floats pretty well. It is not the best on hard pack and trail but not terrible in my opinion.
From my experience, the Yeti ski is about the best in really deep powder, but it is one of the worst in set up snow or trails. I really like the Camso ski for overall performance. The spindle is ugly but functions well. The flotation is good, traction when carving is predictable, and is fairly stable on trail.
Jan 14, 2004
2,893
1,168
If you go back you will see there are a ton of these Best Ski threads. Its not to say its a bad topic but as time goes on we are seeing more and more guys that are mixing and matching brands of kit, spindle and ski. A ski discussion IMO is incomplete without a discussion of what the ski is being used on. So many factors affect ski performance from ski pressure, spindle height, fork height in the tubes, limiter straps ,fork rake, fork springs, rear shock preload, ski trail, mods to the runners, the list goes on and on. All the skis out there have their inherent strengths and weaknesses, if there was one that clearly was dominant everyone would have it already be using it exclusively. Again, IMO, so far there isn't a bolt it on and go magic ski bullet you probably need a couple of skis depending on your setup, I have 2.
CATSLEDMAN1
2,483
1,034
Missoula, Montana
As M5 says, lots of options..............for set up. If you want to bolt it on and never look at it, there are no answers. For me the ARO hands down. More float ? Been there, no good. Do I run the ARO the way Polaris sold it to me, not after the first day. If you ride enough and pay attention you can fit the ski to the bike. I have ridden some skis that I wouldn't want to try and tame. I think of them as one dimensional skis............good for one condition. Ski development has come a lot further than drive units from day one until now . WOW, after building our own skis the first 3 years of snow bikes the handling NOW is so good now by comparison, skis are almost a non issue by 2020. A better ski to come, for sure, I hope so, for me now, 6th on tracked up mtn roads headed back to the truck tired and going down hill and nice relaxed riding, years back I thought sno bikes would never get here.
Jan 4, 2015
143
54
Qc, Canada
What did you do to the ARO ski ?
needpowder
1,290
355
83
45
Utah
All around the ARO ski with the outside edges trimed down to 50% hight with a taper from 0 to the 50% hight by mid point and the dual runers in the Middle does everything well and is by far the best on the trail.
That sounds pretty similar to what I am running on mine. I wouldn’t say I am down to 50% height on the outside but I took a little off. More importantly was grinding down the front of the middle runner so I didn’t hang up on stuff. Early season, logs rocks or whatever. Late season, dirt pavement whatever. Grind that thing down!
Dec 20, 2007
659
302
I'm still gonna say the old back county ski is best all around especially for 2 strokes or riots that have less ski pressure. The Aro is real close 2nd and probably better for heavy bikes and people who don't ride in the spring. Camso and yeti both have Jekyll and hyde conditions. I wish the cmx was around for me to test but I've never seen one in the wild.
Nov 28, 2007
1,793
750
Yukon Canada
I agree with both posts above the old ski has an edge in the hardpack and the Aro ski has the edge in the pow both are good all arround and above average on trails as long as the runners are massaged properly and the suspension and bike set up is right.
CATSLEDMAN1
2,483
1,034
Missoula, Montana
If the " old back country ski " is the TS ski before the ARO ? Is that what we call it ? If thats so, that ski is only good to cut up for plastic chain guides and other shop projects. Side by side tests with the ARO and that ski switching back and forth, its a poor cousin. Stock out of the box setup on that ski/spindle, first good wide ski.......yeah, its a ski on a trail that sent a lot of guys back to the sleds........bad. I can make that ski and spindle a one hand 6th gear cut up trail ski, but any other condition when the snow is more than 3" deep and tracked up a little, just bad old superseded design/construction. The old ski worked great in deep powder, most all bad skis work in powder. OK, I been locked up in the shop too long.
Jan 3, 2008
668
249
Northern Utah
Please send me all these skis before you cut them up......
Feb 28, 2011
14
1
3
As the season closes I've learned the Timbersled Backcountry ski does work really well, at least better than the ARO, in the heavy slush and old snowmobile trail crud. So I guess it does have a use after all.
Hawkster
1,269
628
AK
:) There is no do all ski , conditions vary as does the required ski pressure and flotation for those conditions .
Congratulations Boneless by that comment I'd say you just took your riding to the next level .
Have you noticed if it helps alleviate some arm pump ? Doesn't flex as much as it's older faster Gen II but has a lot more traction . The Gen II is still my go to ski for speed , you won't believe how much more throttle the machine has with a faster ski till you experience it .
Dec 20, 2007
659
302
I still have a gen 2 and can attest to it's speed and no arm pump but it has no corner grip until I added some wings. But I wonder why no one notices the camso acts like a gen2 with wings? it's kinda the same but more banana shaped.
Neither was very good on trails. Something about the dual runners just don't feel like a tire to me at all.
