Belt drive, lighter, more efficent, spools up faster, simpler, makes tracks swaps a breeze.
chaincase, is heavy, slower and makes tracks swap a much larger task.
Especially with the QD2 on the '21s and on all models I personally see absolutely no reason to opt for a chaincase now.
That just can't be true!
Oiled steel to steel friction must be a lot less than dry rubber to steel/aluminium!
What makes me most skeptic to belt drive is the running cost. The service life of the belt isn't that long and at least over here the belts are expensive as heck!
I've said it before and I say it again, justifying the belt drive needs a fair bit of placebo!
I might not nowadays avoid a belt drive sled but I wouldn't put one on a sled that wasn't equipped with one regardless of how much money I had laying around.
That's all??You need to try it before you comment. The longer the chain, the more the belt is noticeable. Polaris has a relatively short chain so Doo and Cat see more benefits as they are longer. That said, these belts are lasting for years. I have a TKI on my 2015 ProRide and it has over 3000 kms on it and I bet it goes to 4000 easy.
That's all??![]()
