Important BCA ANNOUNCES VOLUNTARY RECALL OF LIMITED NUMBER OF TRACKER4 AVALANCHE TRANSCEIVERS
27,375
Tracker4 Voluntary Recall Press Release
Backcountry Access (BCA), in cooperation with the US Consumer Product Safety Commission (CPSC) and Health Canada, is issuing a voluntary recall of select Tracker4 avalanche transceivers. The units bear serial numbers that start with 21H05 or 21H06 and were sold from June 2021 to February 2022.
The reason for the recall is the toggle switch can separate from the transceiver and prevent it from switching to search mode, making it difficult to locate a skier or rider in an avalanche.​
27,375
Backcountry Access (BCA), in cooperation with the U.S. Consumer Product Safety Commission (CPSC) and Health Canada, is issuing a voluntary recall of a small number of Tracker4 avalanche transceivers due to a switch plastics production issue.
This issue impacts certain Tracker4 beacons with serial numbers that start with 21H05 or 21H06 sold after June 1, 2021. The affected units may have been purchased as a part of a Tracker4 rescue package or as a standalone unit.
The reason for the recall is a switch plastics production issue that may result in the switch falling off the transceiver. If this occurs, the user would not be able to turn the transceiver on and off, preventing the ability to transmit or search for a discoverable electronic signal in the event of an avalanche. There have been no reported incidents in which the Tracker4 switch issue has contributed to a fatality, injury, or other damage.
Consumers should immediately stop using any Tracker4 avalanche transceivers with serial numbers that start with 21H05 or 21H06. To determine if a unit is affected, look for the serial number inside the battery door. If the serial number begins with 21H05 or 21H06, BCA will replace it with a new unit at no cost. To register for a free replacement unit, complete the Tracker4 Recall Replacement Form.
GO TO THE TRACKER4 RECALL REPLACEMENT FORM
DOWNLOAD TRACKER4 SAFETY RECALL BULLETIN
USA​
Backcountry Access
2820 Wilderness Place, Unit H
Boulder, CO 80301, USA
Tel: 303-417-1345
CANADA​
K2 Sports Canada
1 Westside Drive, Unit #7
Toronto, Ontario, Canada M9C 1B2
Tel: 866-455-2748https://stg.backcountryaccess.com/support/t2-update-form
EUROPE​
K2 Sports Europe GmbH
Seeshaupter Str.62
82377 Penzberg, Germanyhttps://stg.backcountryaccess.com/support/t2-update-form
NORWAY​
K2 Norway Madshus
Industriveien 29
2836 Biri, Norway
Tel: 0047 61 13 43 00https://stg.backcountryaccess.com/support/t2-update-form
JAPAN​
K2 Japan Corporation
6F TMM Bldg.
1-10-5 Iwamoto cho, Chiyoda-ku
Tokyo Japan 101-0032
Tel: +81-3-5809-1904https://stg.backcountryaccess.com/support/t2-update-form
Tracker4 Recall Replacement Form (Japan only)
27,375
PLEASE CHECK YOUR SERIAL NUMBER. IMMEDIATE REPLACEMENT OF YOUR TRACKER4 MAY BE WARRANTED.​
To determine if a unit is affected, look for the serial number inside the battery door. If the serial number begins with 21H05 or 21H06, BCA will replace it with a new unit at no cost. To register for a free replacement unit, complete the Tracker4 replacement form.​
BCA stands behind the quality of our products, and the safety and satisfaction of our customers is our top priority. Thank you for your attention and cooperation.​
