Ascender can
853
utah
i've used a Cutler can on my 20 alpha and also 19 alpha as well as previous m-8 sleds....good product, never cracked, no bogs due to fueling, etc....no bogs due to deep snow....not too loud....no problem recommending this can..and i think the price is $299.
joshkoltes
3,474
872
ranchester, wy - nashua, mn
I use the bdx. They are light and not loud. Two choices stainless and titanium. Might still get in on the weekend deal. I think it was 220 for the stainless and 320 for the titanium right at two pounds
The top of the line would be a diamond s which is pretty light, very quiet, but super expensive like 600 bux
The ggb is the cheapest cause all it is is a steel pipe. they are ear piercing loud and cheap.
ultrasks700
450
153
MAINE
I have the SLP on mine. i ride in noise sensitive area and the SLP has a great low end tone without being too loud @ WOT. I have several other Acender owner firneds who run them as well and love em.
Apr 26, 2017
77
29
18
26
I would probably say it comes down to a individuals budget. I started with a mbrp mountain can on my 19. Ran good but was really loud. I finally pulled the trigger on a diamond s titanium can (they are spendy) but I did not look back. It's the lightest can on the market, which personally I believe should be anyone's primary goal in running a can (shedding weight). Yeah, I get loud cans sound cool... but it's more about letting your riding do the talking, rather than the noise you can make. Most can's actually make a sled lose power versus gain. I felt the diamond s made the sled run a little stronger than mbrp can did. I'd still be running it if I didn't go to a turbo. Definitely worth looking into. Otherwise I've had good luck with HPS as well.
Aug 28, 2008
335
35
North Central MN
I really liked the sound of my GGB mountain can. I had every intention on getting another until I heard that some experienced bogging with the new engine. The less I spend the better, especially if the wife gets involved...
I really like the looks of what HPS has done as well.
cooker2003
New member
6
GGB Mountain on my 2018 High Country had bad bogging problems two winters ago in Cooke City. Cat did reflash the ECU, but I haven't been back at elevation to see if there was a difference. I can't definitively say it was due to the GGB exhaust.
Sent from my SM-G892A using Tapatalk
bjd68
224
52
Abbotsford BC
I just put a GGB trail can on my 18 mountian cat it sounds good in the shop but havent had it up the mountian yet !
snosurfer
45
18
8
I'm running the HPS on my 19 alpha looks nice definitely makes the front end lighter feels like a little more power but that could just be the rumble effect, doesn't bog at all, deep throaty sound at Idle ,not to loud for rider at w.o.t , but your buddies no where your at for sure. My only complaint would be on the trail at a consistent 6000 rpm range it has a pretty consistent resonation that gets annoying after a while making me think of putting the stock suit case back in if I had to ride trail very much, thankfully that's not the case, just my 2cents worth, otherwise performs quite well.
Nov 14, 2012
37
20
8
Running SSI stainless can on my 2020 hardcore. It seemed to want to pull backwards toward the chaincase and then was rubbing/vibrating metal on metal. I added the extra spring to the front to keep it centred.
Noise levels was a little more than expected but not bad. A little annoying on the trail to the mountains but once in the deep it was fine.
Qreiff
623
Colorado
I run the SSI Ti can. Uber lightweight and fit was great. A bit noisy on the trail but there are many cans out there much louder. No bog......sled runs crisp and smooth in all conditions.
