schu
New member
For Sale, Arctic Cat 1m mod sled.
Here are the specs:
1000 big bore engine built by mad max (cutler 1000 pistons)
Cyl and case porting.
Pinned and welded crank.
Speedwerx big bore single pipe (runs like a stocker with way more power)
Speedwerx y pipe
super-q can
Rifle bored carbs
Kick *** filters
RTK head
Cat 6 tower clutch
Boss high rise seat
Holtz front suspension with fox zero-pros
Holts rear suspension with fox zero-pros
Digatron 4 window EGT gage (just got it back from being updated)
Simmons Skis
Snow eliminator running boards
Camoplast 156"x2.5" 3" pitch track
8 tooth extrovert drivers
151 rails with 2.25" set back for flotation.
19/43 gearing HYVO gears
Supreme tool super tips adjustable weights
Heel clicker-X decreasing radius secondary clutch
Stock secondary clutch cover for using cat helixes
Cat 159" tunnel with aluminum rear bumper
cut down rear cooler
Mod shop firecat fiberglass hood
good plastic
Fly Aerotaper bars with heaters
Forward mount steering post (same stance as an M8)
Clear fuel tank for the tunnel with custom mount.
Dry weight is probably 470ish maybe less
Basically the bulkhead and fuel tank are stock.
I'm selling this sled for a few reasons. My dear friend and riding buddy died last winter in petersville. I've built more sled than I can ride. I've lost interest since I'm building an airplane. I can use the money for other stuff.
The sled runs very strong, is in good shape, and is reliable. I've never burned down the engine and it's always taken me back out of the mountains. That said, it is a mod sled, so it's fairly loud (though not nearly as loud as some), it does vibrate, it's a monster to rope over, and if you aren't careful it will get you into trouble (it's very, very fast.)
I'm looking for $5000 since the that is what just the engine, track, gage, and pipe goes for, but I'll negotiate a little depending on interest.
If your looking for something affordable that will annihilate an 800 on the hill then this would be a good rig for you.
Call my cell or email if you have any questions or want to look at it.
907-354-7249
schu@schu.net
Note: The gage isn't in the pictures since I mailed it back to digitron to be updated. It will be like new when the sled is sold.
Here are the specs:
Speedwerx y pipe
super-q can
Rifle bored carbs
Kick *** filters
RTK head
Cat 6 tower clutch
Boss high rise seat
Simmons Skis
good plastic
907-354-7249
schu@schu.net
