Hi all, first post
bought my first ever sled last week, 2008 M1000 efi. 1300 miles. I’m new to sleds but it appears totally stock.
test ride consisted of a couple WOT pulls in a field,no issues there.
1st ride after purchase I went to a local trail. Sled started bogging noticeably shortly after warm up at all different RPMs. Limped it back and brought it into the garage.
Did a few diagnostics and test rides in the field by my place. Bog/hesitation has gotten worse.
so, here are my symptoms
-Sled starts great
-after allowing it 4-5 minutes to idle and come up to temp I hop on and go for a ride, 1st few minutes go ok
-sled starts bogging to the point of coming to a dead stop and barely running. sled will sputter and die if I give it throttle at this point.
-starts right back up, idles great
-I start feathering the throttle and can usually get it to slowly build some rpms
-finally builds up throttle and zoom! Off we go, sled runs awesome for 20ft to 100 yards, starts bogging again, process repeats.
It’s running like a carbed sled with dirty carbs.
here’s a few things I’ve done so far
-compression test:124 and 125 psi in the cylinders. Pulled intake, 1 cylinder does have some light scoring. Nothing major and not enough(I don’t think) to cause my issues
-pulled and inspected plugs. They looked new and were probably changed right before I bought it.
-cleaned power valves. They were clean but I had them out so I cleaned them up
-unplugged TSS, TPS, and kill switch. Issue did not go away
just wondering if you folks have any ideas to throw at me. It’s seems to be running lean, I’m trying to determine if it’s part of the fuel system(injectors, fuel pump, smart valves) or perhaps on the electric side(stator, grounded wire).
this is my first sled. I’m not a mechanic by any means but do most of the wrenching on my trucks and heavy equipment at work. My apologies if I seem clueless(I am)
-Sled starts great
