##2021 Season Low snow mod update-video##Another (better?) no weld solution for tunnel shortening.
Murph
Polaris Moderator/ Polaris Ambassador/ Klim Amb.
I went a different route on shortening the tunnel/ cooler— also using MTNTK products. I liked it so much, I became a dealer for them.
I installed their five foot cooler and plumbed it in, omitting the stock cooler completely.
First I tested it without cutting the tunnel at all— to confirm cooling capability. After running the whooped out trail with no snow flap and only hitting 131 degrees, and then running between 88-93 degrees in deep snow, I took the plunge and made the cut (7”)last night.
Shortened tunnel ride today.
I really like how the center cooler keeps the center of the tunnel free of snow/ice buildup
⬇⬇⬇⬇⬇⬇⬇2020-21 Season update/ modification for low snow conditions ⬇⬇⬇⬇⬇⬇⬇⬇⬇⬇⬇⬇⬇
Tags: Tunnel cut, Tunnel shortening, MTNTK kit, Tunnel chop, No tunnel weld solution
541B1C06-F5DC-4311-B6E1-95E385F66E4A.jpeg E020FBBD-642F-4F04-A0D4-DC3DC0BDC19F.jpeg 3E987CBE-EBD5-48C7-AFCE-F7B1F5D91484.jpeg 51F985B5-BEE7-4051-828B-FC697C66B8A7.jpeg BA139519-5C4F-4D49-9A1E-C8DCA8711900.jpeg E862EE06-9DCE-4DE5-8813-973B39C4F9B8.jpeg B9F82568-FC3B-4A1A-92D5-60C05B5B7066.jpeg 5AE84AE6-6D5A-4519-8450-402676298509.jpeg
neden
37
18
8
Sweden
My cousin did this last year on his RMK 146" build. It has been working flawlessly! ? Temperature has been exactly the same as my 155" when I have compared them. And little less ice build up on the running boards too.
Sheetmetalfab
7,910
6,671
This would be the real benefit.
I’m thinking I should do it even with a cut tunnel.
Turn that poo oem tunnel cooler into an auxiliary fuel cooler.
Norway
1,978
476
83
49
ha!... I’ve been thinking the same thing. Along with plumbing a bulkhead cooler in series for no snow build up.
This! Snow build-up!
Pro and Axys are light, and although I dont subscribe to Cats presentation of the difference in weight including snow build-up, it is a significant drawback..
Add the ice chunks on the inside leg of your bibs, and I am ready for a change.
Sent fra min S60 via Tapatalk
MTNRCR
I'm a little concerned with cutting off the crossover exchanger and not replacing it as this is part the tunnel structure. My guess is those that have will start to see cracking at the bottom of the tunnel side plate just behind the rear suspension mount much earlier then those that have welded the cross cooler back in. Just what I'm thinking.
