I added a roll out calculator too. Just Click the link, enable editing, and have fun!
Can you do that for the 6 speed tranny please it would be very helpful. Thanks!!!I have the file in my previous post
what bike are u running?
I am going to try the stock setup 13/17/17/20 it was way to low geared on my 530excr that's how I ended up with the 12/17/20/17 it runs great all mountain and ran nice with the old kit but now it rubs the track. I ran the 14/16/17/20 on my 530 and it was ok but not perfect. I think it is just this goofy wide ratio tranny on the EXC that I'm dealing with. I will probably put a 14/17/17/20 after another ride or 2 it should fit. I do like blue might have to go track one down eace: Thanks
MtnDoo are you saying 13/17/20/17 ? Thats like .042 final. Thats pretty tall no ?
Ryan, try a 13/16, then the stock 17/20. That should get you close.
Ok I have purchased and installed an 18T and 19T for the chain case from 9Miler and for the KTM 500 exc this is a very large improvement over the stock gearing. First gear is actually some what usable and it is a little taller geared throughout. very easy to swap over with this setup, uses same chain length and tensioner also you do not have to remove any of the case mounting stand offs. just swap out the sprockets and tighten chain like normal.
13-17-18-19
:clap2:
I have the KTM 500 exc with the LT. The best gear combo for my snow is 13-17, 16-17. I have a tiny tach so i used that to get the right gearing in the peak power zone. 3rd gear is my terminal powder hill climbing gear
