A
We are excited to announce the addition of all 2012 Arctic Cat two-stroke snowmobiles to the Aerocharger lineup. For the Arctic Cat we have two turbo system options. An Air to Water intercooled system and a non-intercooled system. Both systems allow you to keep the headlights and do not require you to cut or weld anything on the pipe.
The air to water system utilizes the factory coolant loop to make the installation as easy as possible while keeping the air charge temperatures cool and extremely consistent. This will provide maximum power as well as making tuning the sled a non-issue, just pull the rope and go. We are also offering a non-intercooled system for the sleds. This system is simpler to install, lighter, and still has excellent performance. Both systems will utilize a 66 series Aerocharger with a 200 compressor wheel and a .250 turbine wheel. This turbo has been sized for all boost levels from 5-14psi. Like all Aerocharger turbo systems there is no need to cut or weld the pipe.
We include an anodized and laser etched gauge pod to hold our boost gauge and Innovate Air/Fuel ratio gauge. We use the new Innovate MTX gauges in all of our systems due to the improved water resistance as well as sensor durability, when compared to other gauge manufacturers. If you ever need a new sensor, you can just go down to your local auto parts store and get a new sensor.
Both Arctic-Cat Aerocharger systems are going to have our new patent pending airbox included, removing the need for the rising rate fuel regulators seen on almost every Arctic-Cat turbo snowmobiles. The system will be capable of running on pump gas as well as race gas, while only adjusting your clutch and boost level. These systems will be available to factory backed racers the before Thanksgiving and to the public shortly after. All of our systems come complete with an easy to read instruction manual full of detailed pictures to make your job as easy as possible. After you have the system bolted up just add fuel then pull the rope. All kits are capable of running on pump or race gas, just change the boost and away you go.
This Turbo System Includes:
66 Series VATN Aerocharger
Turbine Heat Shield w/ Insulator
Air/Water Intercooler
Custom Air Box
Insulated Muffler
Polished Aluminum Charge Tubes
Billet Blow-Off Valve
Adjustable EFI Controller
Billet Secondary Fuel Rail
Dual Secondary Injectors
OEM-Spec Fuel Lines
Wide-Band Oxygen Sensor
Digital Wide-band Gauge
VDO Boost Gauge
Aerocharger Gauge Mount
High Flow Air Intake
Installation Hardware
Installation Manual
Fuel Tuning Manual
NO CUTTING OR WELDING
Custom Air Box
Insulated Muffler
OEM-Spec Fuel Lines
VDO Boost Gauge
Installation Manual
Fuel Tuning Manual
