• I've received emails and PM's asking me about "Group Buys" and promotions.
    A Group Buy here on SnoWestOnline.com would be a situation where a normal member (non vendor or mfg) personally collects orders from other members. That member then uses those orders to negotiate a better price with the Vendor/Mfg for HIS/HER "Group" of buyers.
    Here is an example of a viable "Group Buy"
    http://www.snowestonline.com/forum/showthread.php?t=269222
    A promotion that has the words "Group Buy" in the title is still a promotion, and from the rules that were handed down to me by Harris Publications is that non-advertisers cannot run promotions or open sales programs on the forums outside of the swapmeet.
    If a members wants to become a group buy manager, maintain a thread and collect the funds and negotiate a group buy... as a member, you are welcome to do that as long as you are not attached to the business of the vendor or Mfg.
    If you are a vendor/MFG and you want to offer an EXCLUSIVE "SnoWestOnline ONLY" promotion that is exclusive to snowest readers, please contact me and you'll be able to put it up in the Polaris forums.
    Also, before any vendors/mfgs get all "riled up" over this know that the moderators are strictly volunteers and do not receive a dime from any advertising $$ spent on this site.
    As ALWAYS, since DAY ONE of me becoming a moderator, I have pioneered, supported and encouraged vendors and mfgs in getting the word out to our readers with "New Product Announcements.
    Have a great season.
    From this point on, all vendors/mfg's promoting Pre-Season tiered sales programs, in the Polaris Forums, that are not paid advertisers will be appropriately moved to the swapmeet section of the forums.
    MH
99 XC 600 backfire and stalling
extremeattack
31
Gillette, Wy
Have a XC600 twin. First off I cleaned the carbs.
Sled idles fine.
It will some time run fine with good RPM and speed.
It will also back fire or fall on its face when you pin it.
The problem is not consistent.
sled_guy
3,561
841
Riverton, Utah
Does it do it only when it is not warmed up good or does it do it even if the motor is good and warm?
Has Keihin carbs doesn't it?
sled_guy
sno*jet
2,272
784
musta put something back together wrong. air screws where they should be? hoses conected to airbox? how about your spark plugs...
keihen carbs had a problem wallowing out the holes where the float pins press through. Ive seen em run ok like that tho.
extremeattack
31
Gillette, Wy
I pulled the carb out because of the backfire. Tried new plug didn't help. Going to pull carb again and check float. Going to check voltage regulator. I forgot to mention the lights are not on. Where is the ground located on these sleds?
