98 RMK 600 Brake Problems
The brakes on my sled worked fine until i rolled it and the handlebars got bent. I have tried to blead the line but it hasnt helped. What ive done is loosened the breather and when i squeeze the lever and hold it a little bit of fluid comes out. When i tighten the breather the lever still goes clear to the bar with the fluid full.
Is this the right way to blead them. What could the problem be? I kind of ruled out the pads because they worked until i rolled it.
treetopflyer
74
31
18
59
im assuming you cracked the fitting on the master cylinder. its a sealed system. rolling the sled over should do nothing to the brakes.check for leaks.
