K
95 Indy 500 Motor Swap Question EFI 2 Carbed
Hello,
I recently purchased a carbed 95 Indy 500 without a motor. I then bought on line a 92 SP 500 engine which was EFI with no fuel rail or intake boots.
Question I have if I purchase the EFI boots for the 92 SP 500 Engine will they work with the 95 carbs? I know that the intake boots for the 95 will not work on the 92 engine because the bolt hole spread is wider on the 92 than the bolt hole spread on the 95 intake mount holes?
Has anyone out ther used an EFI engine to replace a carbed engine or vice versa? And if so what did you do to make the carbs work?
Thanks
Hello,
Thanks
