93 700 wildcat
run at idle with oil pump arm pulled wide open until the garage is so full of smoke you choke. check oil line for bubbles, shouldn't be any. Make sure 1st tank of gas has 60:1 oil in gas, you're ok.
There is a bleed screw on the center of the pump. It looks like a bolt that screws in with a 10mm head. put a rag under the pump, and remove the bolt and let oil run out until all the air is out of the supply line and re-install the bolt. Then do as already mentioned, and hold lever wide open at idle until lines are full of oil. Of course do all of this with some premix in the tank, and you are good to go.
i used stainless wire to hold the arm wide open.premixed first tank after top end,the oil bucket showed no use after about 1 hr-will look closer for bleed screw,thanks!
