R
I went to replace my water pump belt today and found that the groove on the end of the water pump shaft is starting to wear and round off on the inside edges where it contacts the oil pump drive. Would it be a good idea to replace this or could I get away with it for the season? I already know the answer to that question but entertain me any ways. How hard of a fix is this and what seals and gaskets should I change if I decide to change this?
Another thing I noticed was a small puddle of oil of some sort had collected in the stator housing almost directly below the stator. Its seems like wherever this came from it hasn't been there too long cause it wasn't spattered all over the inside of the housing. The machine hasn't ran since last march and I fogged the motor last spring. What could this be? Dried out or blown seal is all i can think of. Hope not!!
Also, should there be a gasket between the recoil and stator housing and should the hole above the stator be plugged or open so it can vent. Sorry for a lengthy post, thanks for any input.
