M
maxnorfolk
New member
Just wondering if anybody actually knows the difference between the 670 and the 670 ho engines?
I believe the timing is advance due to the key slot on the crankshaft is a couple of degrees different than a regular 670 motor.
I've posted this a couple times before-
X/H.O. - notch cut in rear of cylinder sleeve to open up rear intake transfer, 44mm carbs (40mm on std), short intake boots, RV cover with larger openings, factory tunnel-porting, flat-top pistons, different squish on head domes, RV valve with more induction timing, larger volume pipe........
That's about it. Ignition is also different, as the X/H.O. engines use DPM
