Note: this_feature_currently_may_not_be_available_in_some_browsers
Frog skin............Dave, what keeps the pow out of that top vent? Looks like snow/ rain would get on the secondary/ belt. Thanks for the info.
won't know till final, things might change, also single button gauge on all summits unless 10.25 gauge, no 2 button are availableDave, appreciate your video but I do have a question on the exhaust side. The small clips in the front side of the panel suck! Is Ski Doo going to re-engineer the panel or maybe get rid of the small clips and add a rubber strap like the clutch cover has? This is the only problem area I saw when I was checking the sleds out. As a matter of fact, the small clips on the Expert were different then the small clips on the X model.
Thanks again!
If theres frog skin on that top vent it's sure hard to see. Dave grabs the vent and puts his hand through it.Frog skin............
No two button even on the Experts????won't know till final, things might change, also single button gauge on all summits unless 10.25 gauge, no 2 button are available
there is not as that is an exit vent and it is not directly to the clutches it is behind a the cvt cover that is part of the door, so snow would have to go in there side ways down around the venting down and then up to get to the secondary, it does not happen. There is slp on the intake, where it needs to be.If theres frog skin on that top vent it's sure hard to see. Dave grabs the vent and puts his hand through it.
there are only 1 button gauges available, so yes.No two button even on the Experts????
Damn, that didn't take long to ago sideways. The website and brochures say 2-button gauges. I just ordered my sled last week and it said 2-button gauge.there are only 1 button gauges available, so yes.
you can cancel, if it does not suit you. sleds are prototypes until production, they are only using things they can get so customers get their sleds when they want them. cheers daveDamn, that didn't take long to ago sideways. The website and brochures say 2-button gauges. I just ordered my sled last week and it said 2-button gauge.
How could Doo not get that right out of the gate?
Suit me? A $500 non-refundable deposit was required to order so that ship has sailed.you can cancel, if it does not suit you. sleds are prototypes until production, they are only using things they can get so customers get their sleds when they want them. cheers dave
new boards/suspension/bodywork/ledlights/enclosed cvt cover/4 motor mounts/track change without opening chain case/easy to remove rear suspension bolts..........but wait what only 1 button on gauge, man some guys are never happy. then back out there will be others to take your place.
The second button switches the sled to run on Diesel!When gas is $8.00/ gallon the single gauge button will be the least of your thoughts.Don't think about 2023 until we get thru 2022
Who would ever want that!! Have you seen the price of diesel.The second button switches the sled to run on Diesel!
