2020 silber kit heat exchanger
Aluminum.magnet
Can’t find any information on how to run the coolant hoses to the heat exchanger. The coolant lines for the turbo housing are labeled but nothing about what throttle body coolant line I assume to connect into the heat exchanger. Any information would be appreciated, would like to get out and get some miles put on but don’t want to guess wrong and do damage.
You talking about the new intercooler intake housing cat kit?
did you get it figured? you just loop the coolant lines to the cooler then to the turbo. will likely have to pull the one hose barb out that was preinstalled
I got it figured out. Mag side throttle body coolant line to the heat exchanger, PTO coolant line connects to union fitting
So you hooked it up so the coolant lines does not go through the throttle bodies anymore correct? That's the only way I could figure out how to do it.
