2020 new spindles information
donbrown
842
Los Angeles
2020 Spindles and Rubber Stop come as a package and are avaialbe in the 2020 catelog to order, there are two tabs on previous model 2017-18-19 skis that you will have to shave down to make the 2020 spindle fit in, it is easy.
What are the part numbers?
SNOBI-WAN-KENOBI
1,770
536
North Bend,Washington
Does the kit show you where to shave down the skis? Thanks
Sent from my SM-G965U using Tapatalk
donbrown
842
Los Angeles
NEW DEEP SNOW LIGHTWEIGHT SKI SPINDLE KIT* • Improves front dynamics when sidehilling.
• 400 g lighter than stock spindle.
• Standard on Summit X with Expert package.
REV Gen4 Backcountry, Freeride, Summit and Expedition 860201976
$219.99
860201976
NHRoadking
510
203
From a 2020 Expert test rider in Snowtech Magazine:
These front suspension changes are easily as impressive as the rear. We found the front end doesn’t dance around nearly as much as it used to. You can put it on an aggressive sidehill with tracks under the snow, and when you cross those tracks, the front end doesn’t give you the negative feedback that Ski-Doo is so infamous for. Instead, it stays straight and true giving you more confidence in the line you have chosen. On the trail, the front suspension and handling is substantially better. This sled feels more like an MXZ on the trail. It corners extremely flat and is very predictable. We think the new shocks with Kashima coating has helped this a bunch. Also, the new ski rubber and spindle are a plus here.
MKULTRA
298
132
quebec, canada
sounds like a sale pitch
Big10inch
926
865
93
What changed on the skid? No coil over or air shock, no 15" stiff track, still has t-motion?
NHRoadking
510
203
Nothing was announced for changes to the skid.
I believe the announced changes for 2020's mountain sleds are:
Running boards;
Spindles, ski stoppers and skis (for the Expert and Freeride); and
Shorter tunnel and new shocks (Expert only).
Mjunkie
1,567
342
83
Ogden, Utah
Running boards;
I think they did some change to the primary as well but this will be my first doo so I'm in learning mode.
Mjunkie
1,567
342
83
Ogden, Utah
Doo you know what they might have done?
I don’t know. The dealer said he thought there was a change to it but he didn’t give details. On the website they talk about a roller bearing instead of using slides and about a weight savings but I’m guessing that isn’t new?
Feb 7, 2009
916
346
Wabush, Labrador
I think you are just talking about the p-drive primary introduced in 2017. Maybe there are new components in there, but nothing was officially released for spring orders.
J-Dog
476
69
Idaho Falls Id
I have not rode one yet but just reading that they run flat around corners like a MXZ concerns me. Are they going to be harder to initiate a side hill than the previous year.
Feb 18, 2009
191
110
It's sooooo easy to initiate a side hill on a Gen 4 if these make it a little harder but provide the improvements they claim it will be well worth it. They claim less feedback on ruts and also eliminates the ski from wanting to point up which caused the track to wash out...
caper11
688
284
Northern alberta
There is more to the expert front end than the spindles and fancy looking shocks. The new front shocks assembly plays a big part in the handling.
