Hi,
I've got a 2020 khaos 800 that developed a serious coolant leak on the way out from riding while coming down a moderately bumpy fireroad the other day. I can't tell exactly where the leak is coming from but I can see coolant showing up on the top front of track on the brake side of the sled. I have investigated all of the fittings and hoses I can access from the engine compartment and have pulled the fuel tank to check the inlet/outlet nipples to the tunnel heat exchanger. All of that seems to be fine.
The coolant bottle holds a level until the sled gets to about 100degrees on the screen, then dumps all of the coolant. I am guessing this is when the thermostat opens. So no leak with thermostat closed.
The heat exchanger looks ok from what I can tell with the track still on... Any suggestions on other places to look before I take the track off?
Is removing the track the best place to start with this?
I haven't been able to see the thermostat fittings and housing yet (the chaincase is in the way) but that seems like it would be too low in the engine bay to be causing a leak that shows up on the top front of the track.
Any advise would be appreciated, I've never pulled a track before and although it doesn't seem to complicated I would rather not do it unless I have to.
Thanks!
Thanks!
