Does the stud go into the water jacket ? Seems like it shouldn’t.If you have a dealer near by and have warranty I'd certainly take it in. Otherwise if your on your own with it I'd remove the Y pipe, and inspect, May need to remove the Stud and use a thread sealant of sort perhaps.
I will take it off before I bring it in.warranty might not like the aftermarket Y pipe. SSI didnt bother to put a cross brace in like some of the others and the factory did.
No. I will do that when I remove the exhaust to put oem y pipe on before I drop off for warranty.Stupid question have you removed your pipe and put a socket/extension on the cylinder base bolt and check to see how tight it is
No cross brace needed, and we are always looking to reduce weight. A lot of little amounts of weight will add up to a lot sometimes.warranty might not like the aftermarket Y pipe. SSI didnt bother to put a cross brace in like some of the others and the factory did.
700km mileage. No turbo. Never got it hot. Anyone else see this ? Notice coolant on bottom bolt for Y pipe. Possible a crack in cylinder. Dealers are busy until August or September where I live. View attachment 348889
