• I've received emails and PM's asking me about "Group Buys" and promotions.
    A Group Buy here on SnoWestOnline.com would be a situation where a normal member (non vendor or mfg) personally collects orders from other members. That member then uses those orders to negotiate a better price with the Vendor/Mfg for HIS/HER "Group" of buyers.
    Here is an example of a viable "Group Buy"
    http://www.snowestonline.com/forum/showthread.php?t=269222
    A promotion that has the words "Group Buy" in the title is still a promotion, and from the rules that were handed down to me by Harris Publications is that non-advertisers cannot run promotions or open sales programs on the forums outside of the swapmeet.
    If a members wants to become a group buy manager, maintain a thread and collect the funds and negotiate a group buy... as a member, you are welcome to do that as long as you are not attached to the business of the vendor or Mfg.
    If you are a vendor/MFG and you want to offer an EXCLUSIVE "SnoWestOnline ONLY" promotion that is exclusive to snowest readers, please contact me and you'll be able to put it up in the Polaris forums.
    Also, before any vendors/mfgs get all "riled up" over this know that the moderators are strictly volunteers and do not receive a dime from any advertising $$ spent on this site.
    As ALWAYS, since DAY ONE of me becoming a moderator, I have pioneered, supported and encouraged vendors and mfgs in getting the word out to our readers with "New Product Announcements.
    Have a great season.
    From this point on, all vendors/mfg's promoting Pre-Season tiered sales programs, in the Polaris Forums, that are not paid advertisers will be appropriately moved to the swapmeet section of the forums.
    MH
2018 Polaris RMK 800 can I run 8" rear axle wheels on stock axle?
Nov 28, 2010
47
19
8
Wonder if anyone is running 8"wheels on stock rear axle on Rmk?
stock rear wheels are 7 1/4"
I have set exactly 8" diameter
Had to change bearing to 6304 to fit
Installed on suspension and looks fit exactly same as stock but is 3/4" bigger in diameter
Gap now between bottom of new slides and flat floor
This gap will be between slide bottom and track clips once installed on sled
Will this create a problem???????
Excess strain on bearings??
do I need offset axle?
Thx for any info on this
Sheetmetalfab
6,181
3,773
Ak
Works just fine.
Helps keep the nose down when climbing.
I’ve done it on a few sleds.
LoudHandle
3,874
2,750
Valdez, AK
Same effect as trim tabs on a boat, or denting the hull just ahead of the transom to help lessen porpoising. The resulting cupping of the track will bring the front down. The 3/8" height difference is in effect always throwing the back of the sled upwards so being behind the sleds Center of Gravity it will in effect force the front end down. It will also add friction and add drag which will detract from absolute performance, but most would not notice. Purists would never go that way, but a very common redneck / low budget change. Being a purist, I'd never go that way, there should be some aftermarket offset axle blocks to move the axel up the necessary 3/8" to remain flat with the rail surface.
