• I've received emails and PM's asking me about "Group Buys" and promotions.
    A Group Buy here on SnoWestOnline.com would be a situation where a normal member (non vendor or mfg) personally collects orders from other members. That member then uses those orders to negotiate a better price with the Vendor/Mfg for HIS/HER "Group" of buyers.
    Here is an example of a viable "Group Buy"
    http://www.snowestonline.com/forum/showthread.php?t=269222
    A promotion that has the words "Group Buy" in the title is still a promotion, and from the rules that were handed down to me by Harris Publications is that non-advertisers cannot run promotions or open sales programs on the forums outside of the swapmeet.
    If a members wants to become a group buy manager, maintain a thread and collect the funds and negotiate a group buy... as a member, you are welcome to do that as long as you are not attached to the business of the vendor or Mfg.
    If you are a vendor/MFG and you want to offer an EXCLUSIVE "SnoWestOnline ONLY" promotion that is exclusive to snowest readers, please contact me and you'll be able to put it up in the Polaris forums.
    Also, before any vendors/mfgs get all "riled up" over this know that the moderators are strictly volunteers and do not receive a dime from any advertising $$ spent on this site.
    As ALWAYS, since DAY ONE of me becoming a moderator, I have pioneered, supported and encouraged vendors and mfgs in getting the word out to our readers with "New Product Announcements.
    Have a great season.
    From this point on, all vendors/mfg's promoting Pre-Season tiered sales programs, in the Polaris Forums, that are not paid advertisers will be appropriately moved to the swapmeet section of the forums.
    MH
2018 800 3"
Big D rmk700
1,082
166
New Ulm, Mn
I have a 2018 with chain case that has a weird tick I really think it is coming from the break this was the first chain case sled I have had since 2012 so not sure anyone else ever experience this?
Thanks Darren
Wheel House Motorsports
29,585
5,066
SW MT
any specific conditions you notice it in more then others?
Milage?
Have you popped off the cover and or checked the oil for particulate?
sledhed
1,532
336
83
Lolo, Montana
Try it on a stand to see if you can reproduce it. Might help you isolate it. Doubt it is the rotor, no more likely than the belt drive sleds anyway. I would check chain-case tension first, easy to do (if you don't know how, it should be in the owners manual how to do it, or just ask if you need to). You can check the filler plug (magnetic) for particulate but I pretty much guarantee you will find some, that is what the magnet is for. Could not hurt to open up the chaincase, check the condition of the internals, check the tensioner (had them break before). Clean it all out and put in fresh oil. But that is a bit more of a chore.
I just picked up a 17 Axys with a chaincase, switched out tracks, and under certain conditions, low speed and off-throttle, I am getting loud clicking / vibration, I figured out it was the clips slapping / snapping against the hyfax under certain conditions. Center driver appears to be not on center and was rubbing hard on one side of the center punched windows. Talked to friend of mine at the dealer and a mechanic happened by, turns out the center driver can drift slightly off center. Check if that is the case... if it is they told me you can carefully drive the center driver back to center with a little persuasion... equally on each side of the center driver...
Big D rmk700
1,082
166
New Ulm, Mn
Have always keep chain tight I have yet to find the magnetic dip stick I am heading out this weekend to summerize my sleds so I will open up chain case and look at track but that track thing sounds like it.
05rmksteve
1,879
937
Brainerd, MN
There is no dip stick on these sleds. The chain case oil plug is low on the chain case facing the foot well. Theres a small hole in the foot well to allow access to the plug.
Sent from my SM-G965U using Tapatalk
sledhed
1,532
336
83
Lolo, Montana
What 05rmksteve said... it is a filler plug not a dipstick, facing an access hole in the footwell, and it is magnetic so wipe it good and clean. My sled with about 800 miles on it, the chaincase oil looked pretty well used and the magnetic plug was doing its job collecting stuff... the track issue was fairly obvious once I looked in the right place, sitting on the trailer and not moving it around by hand, the center driver was over fairly hard against one side of the center-punched windows and looking at the involute driver positions there was no way for the track itself to be that far off center just by happenstance... Let us know what you find out.
EDIT: And be careful not to cross-thread the filler plug when replacing it, not a lot of threads there.
