2017 m8000 sno pro engine speed idle adjust?
kidwoo
2,630
1,875
no
That's an ecu thing.
If you're not idling well, you've got something else going on.
sno*jet
2,826
1,298
im not sure but i thought there was a set screw that the throttle body butterfly pulley rests against, which you could just screw in or out a little to adjust idle if so.
kidwoo
2,630
1,875
^True, you could do it with throttle cable tension.
Isn't there some issue with TPS position vs. the TSS being depressed though?
sno*jet
2,826
1,298
not the cable adjuster but further down on the TBs. should be an adjustment.
throttle cable freeplay might need adjusting after.
kidwoo
2,630
1,875
Sorry, I worded that wrong. Should be the black screw that acts as the stop for throttle bodies where the cable connects.
