Um... been a while, and I have to admit to just slapping in pistons in my Carls 860 since Carls was really tight on their specs. And the prior engine I did, I brought in the cylinders and pistons to dealer and had them check my clearance, then I set the ring gap myself. But the proper way to do it as far as I recollect is to measure the piston diameter (since they can vary a little) preferably with a micrometer, at a number of points, then measure the cylinder diameter also at several points using a snap gauge, and subtract the difference. At least that is the procedure as I recall it. Better get some input from someone else too.Thank you. I looked in my book and couldn't find that.. oh well. It only said 85mm but polaris likes to round and the spec posted shows that. 85mm is 3.346 not 3.34 which is right?? That difference would put your clearance out of spec one way or the other.
Just to clarify when it says piston to cylinder clearance it's talking all the way around right? So double that value and subtract from bore size. .0082- .0106 smaller then bore?
