K
Can I keep the stock 38" bottom arms and replace the spindles and uppers with OEM parts or do I need to go aftermarket? Wouldn't the uppers from a XF or HCR work with them being wider?
Cat sells a 38" upper that fits 2016 spindles. Call Michelle at Cannon Power
Sent from my SM-G930W8 using Tapatalk
Michelle will hook you up with the best deal around. Yes, cheaper than Zbros. This is an accessory part, not available on any sleds.Thanks. Do you know if they're cheaper than the zbros arms? Also what sled do these come on or is cat making them just to upgrade older sleds?
No issues, but I have grippersFor those that have switched to the 16 spindle did you have any problems mounting the skis? Does the older ski damper still work fine? I'm looking for a used set of Powder Pros and on SLP's website they show a new part number for the 16 sleds? Maybe its just lighter?
