2015 pro climb clutch problems
sldrnm
New member
11
4
3
Sled was not freewheeling down steep slopes and wanted to hold me back.Went to adjust belt deflection seemed a little loose so I tightened it up. Still did not seem right so I cleaned the clutches real good but there seemed to be quite a bit of a metallic powder when I blew out the clutches.I am wondering if I might have a bushing going bad. Sled has just over 2000 miles so I ordered a puller but was looking for any suggestions any help would be appreciated thanks.
Old & slow
727
393
Alberta
Check on the inside of the spider where the weight swings, look for wear on the side from a worn weight bushing. Pretty common with that many miles.
sldrnm
New member
11
4
3
So I got my clutch pulled apart and the weights have some pretty good gouges on them. None of the rollers seem to be sticking but judging by the condition of the weights I am thinking the rollers are bad also. I guess it’s time for a Team primary.
boondocker97
4,074
2,794
Billings MT
Weights get "gator backed" over time even if the rollers are good. Seems to start where they contact the rollers at engagement and continues to get worse. I would still think about a replacement at that mileage.
