• I've received emails and PM's asking me about "Group Buys" and promotions.
    A Group Buy here on SnoWestOnline.com would be a situation where a normal member (non vendor or mfg) personally collects orders from other members. That member then uses those orders to negotiate a better price with the Vendor/Mfg for HIS/HER "Group" of buyers.
    Here is an example of a viable "Group Buy"
    http://www.snowestonline.com/forum/showthread.php?t=269222
    A promotion that has the words "Group Buy" in the title is still a promotion, and from the rules that were handed down to me by Harris Publications is that non-advertisers cannot run promotions or open sales programs on the forums outside of the swapmeet.
    If a members wants to become a group buy manager, maintain a thread and collect the funds and negotiate a group buy... as a member, you are welcome to do that as long as you are not attached to the business of the vendor or Mfg.
    If you are a vendor/MFG and you want to offer an EXCLUSIVE "SnoWestOnline ONLY" promotion that is exclusive to snowest readers, please contact me and you'll be able to put it up in the Polaris forums.
    Also, before any vendors/mfgs get all "riled up" over this know that the moderators are strictly volunteers and do not receive a dime from any advertising $$ spent on this site.
    As ALWAYS, since DAY ONE of me becoming a moderator, I have pioneered, supported and encouraged vendors and mfgs in getting the word out to our readers with "New Product Announcements.
    Have a great season.
    From this point on, all vendors/mfg's promoting Pre-Season tiered sales programs, in the Polaris Forums, that are not paid advertisers will be appropriately moved to the swapmeet section of the forums.
    MH
2014 boondocker turbo not running right
x-fire800
New member
Dec 31, 2010
3
So I bought a 2014 pro rmk assault with a boondocker intercooled turbo tial exhaust, 750 miles. The previous owner hadn't ridden the sled in 3-4 years. it would start good but ran crappy when loading it in the truck, i assumed it was due to the old fuel. I brought it home and removed the fuel tank and drained out all the old fuel. I put in a 50/50 mix of race/pump gas. went for a test ride around the yard and its not running right at all. It starts and idles fine but It would only rev up to 6500rpm and also has a hesitation off the bottom end. It also has dual egt gauge installed and when you rev it up the temps increase a bit then once you hit 6500rpm the exhaust temp falls likely due to unburnt fuel. when you rev it up to 6500 and let off the throttle then try to give it throttle again there is very little response for a couple seconds then it will rev back up again. brought it back into the shop to have a look at it and found that there was excessive gas/oil coming out of the exhaust at the y pipe and the exhaust pipe. removed the spark plugs and they were both wet.
I checked the following
-compression 120psi both sides
-replaced spark plugs, checked spark and it appears to have good spark on both sides.
-removed exhaust valves and cleaned
-removed and inspected reeds, they were in good condition no chips or cracks
-visually inspected pistons and they look fine
-i set the settings in the boondocker controller back to the starting numbers on the boondocker website and it was running even more rich and would only rev up to around 5000 rpm
- i played with the settings in the boondocker controller, removing fuel at all stages and it still would not run any better than i started out with, i removed the plugs and they looked more chocolaty brown but still slightly wet. the egt temps would get up to about 650f and then fall off once you hit 6500 rpm
I am going to get a new fuel filter today, not sure if that is the problem as it appears to be running to rich.
Has anyone had problems with injectors causing a similar problem or any other thoughts?
x-fire800
New member
Dec 31, 2010
3
it appears i have found the issue. the boost sensor in the boondocker control box is reading boost when the engine is at idle causing it to overfuel. im sending the controller out to boondocker to have it repaired.
