2014 800 BD pg turbo pre mix ratio?
K
Kbakbmr
Doing the oil delete on my sled and am wondering what pre-mix people recomend. Will be using amsoil interceptor. Bdx recomends 40:1 thanks for your input
My boondocker kit I mix 32:1 runs flawless so far Brent at Arctic edge recommends this running 8-12lbs and 50/50 av gas and premium.
Right on i run 6-8# boost in alaska 1gal of 110 in a 5 gal jug of premium. Motor gets loaded up at idle or coming down a long climb is why im doing oil delete
My M8 would load up a bit coming down long hills and then bog-out sometimes when I tried to get back on it as well. I was always a bit rich on the low end just to keep the motor safe after long climbs. Leaned it up a bit and that helped, but didn't fix it. My long term fix was a cold air intake. Turns out the underhood air was getting hot...very hot. I was seeing intake temps of 200+ degrees. Sled would just puke when that happened. Since the cold air intake, no more issues.
Brent Linderman told me to mix 750mls to 20 liters. Comes out at about 27:1 I think when I did the math... Pretty rich but who am I to argue with Brent...the oil delete help my problem that you explained.
