  • I've received emails and PM's asking me about "Group Buys" and promotions.
    A Group Buy here on SnoWestOnline.com would be a situation where a normal member (non vendor or mfg) personally collects orders from other members. That member then uses those orders to negotiate a better price with the Vendor/Mfg for HIS/HER "Group" of buyers.
    Here is an example of a viable "Group Buy"
    http://www.snowestonline.com/forum/showthread.php?t=269222
    A promotion that has the words "Group Buy" in the title is still a promotion, and from the rules that were handed down to me by Harris Publications is that non-advertisers cannot run promotions or open sales programs on the forums outside of the swapmeet.
    If a members wants to become a group buy manager, maintain a thread and collect the funds and negotiate a group buy... as a member, you are welcome to do that as long as you are not attached to the business of the vendor or Mfg.
    If you are a vendor/MFG and you want to offer an EXCLUSIVE "SnoWestOnline ONLY" promotion that is exclusive to snowest readers, please contact me and you'll be able to put it up in the Polaris forums.
    Also, before any vendors/mfgs get all "riled up" over this know that the moderators are strictly volunteers and do not receive a dime from any advertising $$ spent on this site.
    As ALWAYS, since DAY ONE of me becoming a moderator, I have pioneered, supported and encouraged vendors and mfgs in getting the word out to our readers with "New Product Announcements.
    Have a great season.
    From this point on, all vendors/mfg's promoting Pre-Season tiered sales programs, in the Polaris Forums, that are not paid advertisers will be appropriately moved to the swapmeet section of the forums.
    MH
2014 800 BD Flat
sledhead_79
579
303
Wyoming
2014 800 Boondocker that flat out sucks at 4200-5500ish. Its a dog in that range, but pulls hard once she goes! Its not lag, its either clutching fuel setups.
Cold air intake, external wastegate, air-air intercooler, 6lbs 8500+ elevation
Purchased the kit used last February and seller said tuned and clutched by VOHK. After a ride, I was starting to question if tuned and clutched by VOHK. Contacted VOHK and Eric did recognize the computer setup. When I did through in the clutching, the springs looked awful old. Time to put new springs in!
Well one ride so far this year and sled isn't even smooth like a buddies MtnTek that he has put some time into the clutching.
Clutching is Almond Primary, black/yellow secondary, 40-46-36 ER helix, and 10-68 weights.
Are you guys with BD kits in the PRO RMK running similar clutching?
Any of you that are running VOHK clutch kits have a smooth sled?
Any other types of clutching out there that guys are happy with?
Any of you mind sharing your numbers on control box with me via PM so I can compare mine.
We did drop RPM 4500 down to a 00 00 -01 -02 and I got on it on trail and RPM shot up to 8650 and scared the living $hit out of me, so I put it back at 00 00 00 00. The spike in RPM happened several times with myself and my buddy on the trail. Plug checks looked good while holding 4500 rpm.
Alpine Xtreme Edge
New member
7
4
3
Oregon
Looks like you clutching is the standard boondocker setup out of the box. The 40 degree start on the helix makes the low rpm power delivery very manageable for the masses, but not near as responsive as the rmk was in stock form. I like the 54-44-.36/54-46-.36 which is also what Carl's Cycle recommends for that application. It will give you quite a bit of low rpm response back. The steeper initial angle (54) will load the motor more and have a quicker upshift. The 10-68 should be about right for your elevation and boost. You can use the secondary angle (44 or 46) to control max rpm. 46 will load the motor a bit more, thus lower max rpm.
As far as dropping the #'s in the RPM 4500 range down by 2 points and having the MAX RPM spike, the two shouldn't be related. You would be well out of the 4500 RPM fueling by the time your at max. I kinda wonder if you didn't hit a slick spot with the track completely unloaded for a second to let it spike that high, I also would have thought it would have hit the rev limiter by then but who knows.
I would assume the starting #'s available under the instructions tab on boondocker's site would be close for a 14, but I would always recommend having a Air Fuel Ratio gauge and learning how to set your fuel map for your own specific application. $250 is pretty easy to spend to protect your $5000+ investment and have an all around better/crisper riding experience. Summit racing has the Innovate MTX-L AFR for sale for $155.
sledhead_79
579
303
Wyoming
Rode it 10 minutes since post created and another QD belt snapped, yes I have a deflector. Thinking it was due to the two sharp pointy stumps I found since now i have a big tear in the track. Sled was DET a ton that 10 minutes so I’m gonna set box to bd starting numbers and go from there.
