Latest posts
Forum statistics
Threads
373,843
Messages
4,039,002
Members
109,139
Latest member
TXSledder
  • Welcome to the Snowest Swapmeet section. This is the correct place to be if you're looking to buy or sell something on the Snowest Forums.
    To help you in crafting the most successful advertisement possible, keep in mind that adding these key points to your post may very well help in cutting down repeated questions or confusion about your item for sale and hopefully help you to get your item sold more quickly.
    - If you are using the SW swap meet to list an item, then list the item description here. Don't link it to another website. (failure to do this will result in automatic thread deletion)
    - Adding PICTURES to your post either through the built-in "Attachment Manager" directly from your computer, or by using the [/I] code from photobucket. www.photobucket.com
    - Adding a [B]PRICE[/B] so people know what you're looking to get for your item is very helpful.
    - Adding [B]YOUR LOCATION[/B] either in the post, or into your profile using the "User CP" options at the top of the page. If people don't know where you are, they won't know if your item is worth the drive to get it in the first place.
    - Lastly, be sure to add a [B]DETAILED DESCRIPTION[/B] to your post. If you've got something you want to sell, don't keep it a secret! The best way to get something sold is to share everything you can about it in the opening post of the ad.
    --[B][U]AFTER[/U][/B] the sale: We prefer NOT to delete the thread of a sold item so future users can comparison shop. Please indicate the item is sold in the first or last post. PM a moderator to edit the thread title to include "--SOLD".
    [B]BUYERS[/B]: [B][U]DON'T INSULT THE SELLER BY ASKING WHAT THE BOTTOM DOLLAR IS.[/U][/B] You should see a price listed...there it is. If you want to get down to it, make an offer.
    If you don't frequent the forums, then be sure to add another method of contact to increase the likelihood of a possible buyer contacting you. Though Snowest is a community of fellow snowmobilers, we are not responsible for any information that you post so be sure that anything you do post is something you feel comfortable having out there.
    With these tips in mind, you should now be able to post an effective advertisement for your; part, sled, vehicle, or trailer.
    Good luck and thanks for being a SnoWest Forum Member!
2013 ts 120 kit with many upgrades $1700
CATSLEDMAN1
2,327
912
Missoula, Montana
2013 side panels and frame:
has 2017 TS 120 track
includes 137 extensions for this kit
has 2017 splined front drive shaft
has 2017 splined jack shaft jack shaft
newer o ring chain
new rear aluminum deck and raised more user friendly rear bar
covered, works all the time brake
narrowed rear idler wheels
aluminum top idler wheels that don't rub on the drive lugs
New bearings through out 3/19
stock and heavier chain case cover
bottom of chain case aluminum guard
heat exchangers mounted between frame rails for 500 ktm
both shocks rebuilt several times with heavier compression and rebound dampening and ez fill gas ports, after market springs set up for 210 lb rider
pretty good for a 210 lb rider and 500 ktm
ktm fit kit
2018 ski and spindle ( ARO MODEL ski and spindle )
IN Missoula Mt and sill on my 500., just wainting for new kit to show
$1700 call Mike Hansen 406 240 1726 or text or whats app
pictures to follow
