2013-15 Polaris Pro quickdrive gears / sprockets
sledhed
1,511
329
83
Lolo, Montana
2013 Polaris Pro quickdrive gears / sprockets, also fit Axys and 2014-15 Pro
ANOTHER SET FOR SALE: 2013 Polaris Pro quickdrive gears / sprockets, upper and lower, stock. Also guaranteed to fir 2014-15 Pro and 2016-18 Axys with quickdrive system.
NOTE: With 2016 and newer quickdrive Axys sleds this gives you a GEARDOWN using stock Axys belt, bolts, drivers etc., cheap gear-down to 2.3x effective ratio with the 7 tooth factory drivers... if in doubt, search snowest (using google) to find threads on this gear down method.
Good condition. $150 (NOW $140) shipped for top and bottom gears anywhere in lower 48. Any other location ask and I can figure out shipping.
If you want a new or used 13-15 QD belt (updated versions) just let me know, I have a couple used and one new laying around.
frntflp
310
90
Plymouth, MN
Interested .......thinking .......
According to Polaris website -
15 Pro is 21T upper, 44T lower, 2.095 ratio, belt 2206328
18 Axys is 22T upper, 43T lower, 1.95 ratio, belt 2206046
What's the difference between the belts ? Material ? Length (hope not) ?
sledhed
1,511
329
83
Lolo, Montana
With the Axys, you switch the sprockets to the Pro-ride set and continue to use your stock Axys quickdrive belt. My understanding is the Axys belt is a different length than the Pro-ride, but the material and tooth pitch are the same. There are a couple threads on this in the Polaris performance discussion forum sections, the easiest way to find them is Google search with "site:www.snowest.com" tagged onto the end... if I had them handy I would post up the links. I talked to a guy yesterday who has been running the Pro gears on his Axys for like a thousand miles or more with no problem whatsoever. Not that a dealer "sanctions" this but he works at a Polaris dealership... I am thinking of hanging on to one set in case I find a deal for a used Axys that I can't refuse... :)
sledhed
1,511
329
83
Lolo, Montana
2015 set is sold. 2013 set is still for sale, I would take $140 for those shipped anywhere in the lower 48. I know they fit onto a 2013 shaft as well as 2015 shaft so they will fit an Axys belt drive shaft guaranteed.
sledhed
1,511
329
83
Lolo, Montana
Difference, not
Here is a short video showing the bottom gear free play on a 2015 drive shaft, first is the 2013 gear, second is the 2015 gear, free play looks virtually identical to me, and I know the 2013 bottom gear fits both the 2013 and 2015 shafts and parts guys at Polaris said if it fits a 2015 shaft it will fit the Axys shafts as they are identical. All other measurements on the bottom gear are identical - offset, width, number of teeth, and the top one is identical part number to newer models as well.
https://photos.app.goo.gl/SIMxZ98Ogxg0Y7c02
sledhed
1,511
329
83
Lolo, Montana
Gears were sold BUT I picked up a 2013 as a second sled so I have another set for sale.
I also have two used and one new Pro quickdrive belts left I would part with, about 1000 miles on one, unknown miles on the other (came with sled as a spare) but it looks really good.
I would sell that belt for $75 plus a little to cover part of the shipping cost (split the cost), to the lower 48. It is the updated quickdrive belt since it was original on my 2015 Pro.
sledhed
1,511
329
83
Lolo, Montana
SOLD the 2013 set through facebook... so I have one 2015 set left but I think I am going to keep those in case I sell either Pro I can keep the Kurts geardown kit...
