Hey guys, need some help pinpointing the problem on my 2010 yz450f.
so it's a turbo snowbike setup, and late this past spring I was doing some last runs before season ends, outside temps were warmer, my temp gauge wasnt working and it was overheating on the hillclimbs. Started dying on a hillclimb and loosing power, I thought it was low fuel so I pop a u turn and go down, check to find out it's got plenty of fuel. Tried to start it- no luck. Tow start- no luck. Got towed back the the truck. The turbo setup was used, previously installed on another 2010 yz450f, and I didn't tune it after install. (Dont ask why ?)
Next season is almost here so I decided it was time to fix it. Procrastination at its finest ??.
So it has a good spark. No amount of starting fluid got it to even pop. Compression check- doesn't feel low on compression at all. Bought a new Leak down tester- 9% leak.
While checking out all the cams and timing, I noticed an inconsistency with true piston TDC and the timing mark on stator. The actual piston/true TDC is about 0.8inches before the TDC mark on stator lines up with mark on the cover. Is that normal, or did I bend my crank?
Heres a video I took to show the situation:
Thanks in advance.
Thanks in advance.
