D
doorider196
New member
2008 US Cargo Phantom 48’ Gooseneck trailer w/ living quarters. There is 28’ of shop area and 20’ of living quarters (including gooseneck). Living quarters were custom designed and very spacious. Trailer is loaded with the following options:
Living Quarters
AM/FM RADIO W/CD PLAYER
MICROWAVE
CARPET FLOOR
QUEEN BEEN
VARIOUS STORAGE CABINETS
2-12 VOLT POWER POINTS
30,000 BTU FURNACE
13,500 BTU AIR CONDITONER
12 VOLT DOME LIGHTS
32” WIDE RV DOOR W/SCREEN DOOR/WINDOW
ROOF VENT W/SCREEN
SOFA
DINNER TABLE
TV PREP W/AMP ANTENNA AND OUTLET W/COAX AND SHELF
Trailer Info
6000# RUBBER TORSION AXLES
245/75R/16/E PREMIUM RADIAL TIRES
E-Z LUBE HUBS W/GREASE CAPS
SIVER DIRECTIONAL WHEELS W/CLEAR COAT POWER COAT
STONEGUARD
DOT APPROVED LIGHTING
TWO SPEED LANDING GEAR
1 PIECE ALUMINUM ROOF
DOOR HOLD BACKS ON ALL DOORS
RAMP DOOR W/SPRING ASSIST
2-EXTERIOR 110 VOLT RECEPTS
50 AMP PANEL UPGRADE
110 VOLT PACKAGE
ADDITIONAL 12” HEIGHT (INCLUDEDS 6” TO ALL DOORS)
2-30LB LP TANKS
12 VOLT BREAKAWAY SWITCH W/BATTERY
.030 ALUMINUM EXTERIOR
DOUBLE BULB CLEARENCE LIGHTS
BACK-UP TAIL LIGHTS
WHITE VINYL INSULATED CEILING
BEAD BOARD INSULATION IN SIDEWALLS, FRONT AND REAR
WHITE VINYL LINER OVER 3/8” INCH PLYWOOD WALLS
SPRAY FOAM INSULATED FLOOR
7,000 WATT ONAN GENERATOR
IN-FLOOR FUEL TANK W/EXTERIOR FILL
DOUBLE REAR TAIL LIGHTS
ALL WHEEL ELECTRIC BRAKES
FORMED REAR STEEL DOOR HEADER-ALUMINUM WRAPPED
SAFETY SPRING CHAINS ON ALL DOORS
REAR BOGEY WHEELS
Shop Area
FULL GLASS DOORS
½” RUBBER FLOOR
45,000 BTU HOT DAWG FURNACE
6’ OVERHEARD CABINET
3’ BASE CABINET
6’ WORK BENCH
12 VOLT DOME LIGHTS
2-500 WATT RECESSED QUARTS LIGHTS W/HOUSING
2-55 WATT HALOGEN LIGHTS OVER BACK DOOR
6-110 VOLT WALL RECEPTS
6-4’ DOUBLE TUBE FLOURESCENT LIGHT
ROOF VENT W/SCREEN
2-OIL CAN CABINET OVER WHEEL WELLS (6 SHELVES IN EACH WITH DOOR)
36” SIDE DOOR W/LOCK
IN-FLOOR TIE DOWNS
Asking $26,995
Located in Ironwood, MI
Email: snoxracer_199@hotmail.com or call 906-364-5104 with questions
Living Quarters
MICROWAVE
CARPET FLOOR
QUEEN BEEN
30,000 BTU FURNACE
12 VOLT DOME LIGHTS
ROOF VENT W/SCREEN
SOFA
DINNER TABLE
Trailer Info
STONEGUARD
110 VOLT PACKAGE
2-30LB LP TANKS
BACK-UP TAIL LIGHTS
REAR BOGEY WHEELS
Shop Area
FULL GLASS DOORS
½” RUBBER FLOOR
3’ BASE CABINET
6’ WORK BENCH
12 VOLT DOME LIGHTS
ROOF VENT W/SCREEN
IN-FLOOR TIE DOWNS
Asking $26,995
