2006 Yamaha Apex MT: Electric Start, Reverse, Long Track, 4 Stroke
Bearclaw Powersports
New member
****** 2006 Yamaha Apex Mountain: Factory Racing Blue __*******
2006 Yamaha Apex Mountain: Blue & Black, 150hp, 162” Track
NW Montana
$5500
Are you looking for a nice affordable mountain sled? This sled is pretty much all stock with all the goodies and tons of potential. Easy to adjust electronically controlled hand and thumb warmers that work great. The 162” Camoplast Track is holding up very well. 1700 miles total and this sled runs great every weekend. The 4 stroke sounds great with a throaty sound. No hassle or additional expense of premixing like with the 2-strokes. Fresh belt, oil, and battery. Comes with the Yamaha Deluxe Factory Cover.
It is a turn key sled with all the goodies. Everything is straight, no surprises. This mountain sled has a nice riding position, good suspension, electric start & reverse and a powerful reliable engine. Asking $5500. Add a turbo and you will have the fastest sled on the mountain.
Call Brian at 40six-2one2-43hundred or email me for more information.
Pics can be seen at http://www.bearclawpowersports.com.
Located in NW Montana
Keyword Search:
Apex, nitro, arctic cat, skidoo, ski doo, ski-doo, turbo, rev900 xp, hps, speedwerks, slp, dynoport, rumble pak, powder keg,Polaris, rmk, pro, rmk-pro, dragon, m7, m8, m1000, hcr, thundercat, ext, powderspecial, zrt, Yamaha, mountain, mountain max, sxr, viper,
Here are the specs from Yamaha’s web page:
MSRP* $12,299 (White/Blue)
ENGINE
Type / Displacement / cc Four-stroke, 998cc Cylinders Four
Horsepower Class 150 HP
Cooling Liquid
Bore & Stroke / mm 74.0 x 58.0mm
Intake Design 3 Valves
Fuel Delivery 39 mm fuel injection Ignition Digital T.C.I. w/throttle position sensor Exhaust 2 valves, rear exhaust
Clutch / Transmission YVXC, variable ratio
Disc. Brake Type 4-piston hydraulic w/ lightweight ventilated disc
CHASSIS
Front Suspension Independent, double wishbone
Front Shocks 40 mm aluminum HPG Front Travel / in. 7.0 in
Ski Type Wide saddleless plastic mountain ski
Carbide Ski Runners
Standard Stabilizer Bar
Standard Rear Suspension ProMountain® 162 Rear Shocks 36mm KYB® aluminum HPG
Rear Travel / in. 14.0 in
Track Type Camoplast® Maverick™
DIMENSIONS
Overall Length / in. 131.2"
Overall Width / in. 45.9 in
Overall Height / in. 46.7 in
Track/Width x Length x Height / in. 16 in X 162 in X 2.25 in
Ski Stance (ctr. to ctr.) in. 38 in
Fuel Capacity / Gal. 9.4 gal
Fuel Type Regular Unleaded
Oil Capacity / Qts. 3, Dry Sump
Engine Oil Type Yamalube 4, 0w-30, Cold Weather Formula
FEATURES
Electric Start Standard
Reverse Standard
Hand & Thumb Warmers Standard
Windshield Height
Low Mirrors N/A
Seating Capacity One
Backrest N/A
Rear Carrier Rack Standard
Tow Hitch Optional
Tunnel Protectors N/A
Headlight Watts, Type 60/55W Halogen x 2 High Beam
Indicator Standard
Oil & Temp Light Standard
Fuel Gauge Type Electric (LCD) low fuel warning light
Speedometer Standard (LCD digital)
Odometer Standard (LCD display)
Tripmeter Standard, dual (large LCD display)
Tachometer Standard, backlit (LCD)
DC Outlet Standard (automotive)
Warranty 1 Year (Limited Factory Warranty)
