2006 RMK 900 won't go slow!
L
Feb 24, 2021
8
Seattle
My 900 is giving me fits. It will idle pretty well, but when I give it a little throttle, it dies.
If I time it just right, I can get it going, but I have to go fast. I can ride for a while (a mile or two) and then it will just quit.
It does better when it's cold, but when it gets warmed up, and I let off the throttle a bit to go around a corner, it will die. While it's slowing down to die, I can pump the throttle 3-4 times with no response at all.
I thought it might be the Throttle Position Sensor, so I unplugged it, but even with the TPS disconnected, it still behaves the same way. I tried new plugs, just because, and no difference.
Any experience with this kind of problem? Any idea what might be the cause of this weird throttle behavior?
TecCrash
67
20
8
57
Middleton, ID
Have you tried calibrating the TPS sensor? I don't think just unplugging the sensor will do anything for you. I did mine a few weeks ago, and it made the world of difference. Mine would start and idle, then would backfire and bog from just over idle until about 3/4 throttle then run flat out. I was able to get it back to the trailer, but it was an interesting ride home. The info on building a TPS setting device and the procedure are located in the stickies at the top. You could have a lot of different things going on, but I would start there, and check your reeds while your in that deep.
