2005 RX1 carbs gummed
Shattered1
179
153
Juneau, AK
You can try Seafoam in your fuel, but if you need to clean the carbs, you're going to have to remove them. Take the fuel bowls off and spray everything down with carb cleaner. Make sure your floats and needle valves are operating freely as well and you may need to replace the O rings at the bottom as well.
Givemeaboost
155
Great Falls, MT
Also , if you remove the top caps be real careful with the needles and don't lose the tiny o-ring under the cap.
Ken..........
Givemeaboost
155
Great Falls, MT
Also , if you remove the top caps be real careful with the needles and don't lose the tiny o-ring under the cap. You can get them clean without taking off the caps.
Ken..........
