• I've received emails and PM's asking me about "Group Buys" and promotions.
    A Group Buy here on SnoWestOnline.com would be a situation where a normal member (non vendor or mfg) personally collects orders from other members. That member then uses those orders to negotiate a better price with the Vendor/Mfg for HIS/HER "Group" of buyers.
    Here is an example of a viable "Group Buy"
    http://www.snowestonline.com/forum/showthread.php?t=269222
    A promotion that has the words "Group Buy" in the title is still a promotion, and from the rules that were handed down to me by Harris Publications is that non-advertisers cannot run promotions or open sales programs on the forums outside of the swapmeet.
    If a members wants to become a group buy manager, maintain a thread and collect the funds and negotiate a group buy... as a member, you are welcome to do that as long as you are not attached to the business of the vendor or Mfg.
    If you are a vendor/MFG and you want to offer an EXCLUSIVE "SnoWestOnline ONLY" promotion that is exclusive to snowest readers, please contact me and you'll be able to put it up in the Polaris forums.
    Also, before any vendors/mfgs get all "riled up" over this know that the moderators are strictly volunteers and do not receive a dime from any advertising $$ spent on this site.
    As ALWAYS, since DAY ONE of me becoming a moderator, I have pioneered, supported and encouraged vendors and mfgs in getting the word out to our readers with "New Product Announcements.
    Have a great season.
    From this point on, all vendors/mfg's promoting Pre-Season tiered sales programs, in the Polaris Forums, that are not paid advertisers will be appropriately moved to the swapmeet section of the forums.
    MH
2001 RMK 700 low compression...
Oct 20, 2014
105
7
18
Looking to buy a 2001 RMK 144"
So one cylinder reads 90psi and the other is at 135psi... I can get the sled to start and run, but I have to get on the gas for a little bit... Any ideas what Im going to need to do to get this thing running right? Is it worth me keeping? I am getting the sled for $600.. Just debating if i save my money and buy another sled or hope its ok, rip the heads off and hope its nothing major.
SPI piston kit is $120-180, gaskets is another $60-$100... Anything else I should be worried about? Crank bearings etc?
I already have another RMK, just wondering if this is something I should tackle or pass on as it could be a money pit.
Seat is good, track and skid is good, hood is good...
Thanks.
ryanlinger
289
57
Yakima, WA
Just put new pistons and rings in it. When it's apart check for play in the lower end. Since it will run it isn't completely internally grenaded. If you don't have a manual get one and follow the torque procedure religiously. I failed doing that the first time and blew my gaskets a mile from the parking lot. The 700 is a really good motor and if the rest of the sled is in good shape I would hang on to it. I have the same sled with some mods and love it. Parts are cheap and plentiful. If you have any more questions pm me.
Oct 20, 2014
105
7
18
Thanks. PM Inbound!
Here is a picture of the other issue.... Im thinking the bulk head may have an issue?
SLED
PTO Side Trailing ARM/SKI
That ski is bent way to one side... No idea what would even cause that.. He has another trailing arm, but I looked it over and the current trailing arm looked fine.
The tub and the hood don't seem like they line up for whatever reason. There is a good 3" gap at front. The sides of the hood go into the grooves fine... The hood looks fine/no cracks etc.. The seat is good, the track and skid look good, the NON PTO side of the sled looks fine... Just not sure if it was rolled and something else worse is going on. I couldn't look inside the bulk head and find any major dents etc internally, so not sure what's up.
Oh, it also has 2 pipes that come out of the exhaust... So not stock exhaust either.
ryanlinger
289
57
Yakima, WA
From the view in the picture it looks like the trailing arm took a hit so that may need to be replaced. I doubt it's the bulk head. Looks like the front of the trailing am is bent on and pulling it down.
Oct 20, 2014
105
7
18
Down side is trailing arms for a Gen II are hard to come by...
Cheapest I can find new are $225 an arm.... If it needs 2, that's $500 just in arms... Not to mention pistons, rings, possibly resleeving, honing etc....
If I could find a better deal on some trailing arms I would feel much more comfortable.
ryanlinger
289
57
Yakima, WA
I think edge chassis ones for too don't quote me on that but I think they just don't have the ski stop on the bottom. I bought repairable tubular ones for my sled. Way lighter.
sled_guy
3,561
841
Riverton, Utah
SPI pistons aren't nearly that much...
http://www.hiperf.com/acatalog/700cc.html
You might be able to just rering/piston it... but if the cylinder is hurt then you are in to it another couple of hundred bucks at least.
Hard to tell from the pictures, but I'm betting it took a hit in the front left. He replaced the bumper, but the support structure behind it is probably bent including the hood hinges causing the hood to be aligned wrong.
As for the ski, I'm betting he bent the lower radius rod and either bought the wrong new one or used one that is too long and it is pushing the bottom of the ski out. The mounting saddle might also be bent/twisted. I'd check that ski spindle to see if it is bent too.
You can get SPI made aftermarket trailing arms as well. I have a local guy I buy them from and they are 1/2 of OEM.
sled_guy
rmkid900
New member
Nov 7, 2012
23
3
3
Laramie Wyoming
I don't think Fox made shocks for that sled. that might be part of the problem too. If he threw longer shocks under there and shortened the radius rods it'll mess up the ski stance quite a bit. The 700 is a great motor though i love mine. if you could save it with new rings i'd go for it. But for the hood if the hinges are bent you can fix it right or just throw on a couple extra straps and ditch the hinge. Really what its gonna come down to is the bulkhead. if thats tweaked then its probably not worth it. Thats a lot of time and money to swap in a new one.
Oct 20, 2014
105
7
18
Thanks for the input. Yeah, I can get an EDGE RMK around these parts for $1600, running and in good condition. If I have to put in another $800-900 for a gen 2 chassis its just not worth my time and effort. The front support that the hood hinges on I believe was different, the ski was in bad shape, nearly all the radius rods were bent (on both sides), he said on lakes the sled eats belts, the track, skid, hood and seat were about the only thing that looked decent on the sled.
He had a bunch of electrical lines everywhere, the twin pipes were heating up the radiator hoses and causing a leak before he said.... Just a lot of stuff half way done right is what it looked like to me.
I offered him $400 or told him he might have better luck parting it out.
SledGuy: If I already have the motor apart I would just replace both pistons while I am in there. That's where I got the $120-180 price.
ryanlinger
289
57
Yakima, WA
Yeah it sounds like you made the right decision to pass. I personally have a thing for the gen 2s. Not a huge fan of the edge chassis based primarily on looks lol. I think I'll end up buying a dragon next. If you have any other questions. Shoot. I work night shift now so I'm up all night and sleep during the day fyi
sno*jet
2,285
788
not great motors imo. powerful sure. pull the recoil cover, check the water pump belt, then pull that belt and feel how the water pump spins.... the whole thing prob needs a re-build..
gen 2 was the most boat like hood of them all too :face-icon-small-win
Oct 20, 2014
105
7
18
Yeah,
I have another guy with a 2000 RMK 136" 600cc and he wants $1500 and I was able to talk him down to $1000. It may be a fair price, but still seems high to me. I had a 2002 RMK Edge 700 144" bought in 2003 for $3500, I sold it for $3500 in 2004. People are still wanting $1500+ for a 10+ year old machine.... Just makes no sense to me at all. 136" track is about bare minimum here in Alaska.
ryanlinger
289
57
Yakima, WA
I had a 99 600 and it was alright. It was mint and showroom quality and i paid 1000 for it and that was over six years ago so I agree that it seems high. And a six hundred might not be what you are looking for I don't know that for sure though. And I sold that 600 for 600 bucks a couple years ago fyi. 136 is pretty short anywhere these days that's why I opted for the 159 on my 01
Oct 20, 2014
105
7
18
Well, I decided to buy the sled. It is in need of some some serious TLC, but I wanted a motorsports project this winter... I was looking around at other like sleds and they just wanted way too much with blown motors. This one at least runs (not very well), but it does run. It has a few expensive parts like a westach EGT gauge, twin pipes, risers, different bars etc...
The front of the nose is smashed, that's why the hood doesn't align. So I need a new front bracket.
It's gonna need a pair of trailing arms and other goodies to get it to "like new" condition suspension wise, but the Fox shocks are a nice upgrade.
I figure I will tear down the motor and go from there.
My little triple xlt seems like a beast compared to this dog... Hopefully she doesn't set me back too much.
