E
I have a 99 xc 600 that if have been modd'n this year, long tracked it, team tied it , and lot more stuff , i added slp air box ,slp power rack , v force 3 reeds slp boost bottle ,slp twin pipes with canister ,, followed slp jetting specs the problem is if i hold the throttle at the 5500 to 6000 range it is hesitating sounds like ba ba ba ba ba or spurting if i open the throttle more it stops and cleans up and accelerates like hell , same thing when starting from a dead stop with a moderate throttle not more than 1/4 to 3/8 throttle , accelerates up to a certain speed then start hesitating ,not good because 6000 is the rpm's the motor run at will cruise'n down a trail at a steady speed , tried changing needles up and down and turned air screw out 1/2 turns didn't change, pipes seemed to get hot, plug color was cardboard brown ,if anyone got any suggestions help would be appeciated , i am tempted to put the pipes on ebay but i just got done have then coated by swain tech for 300.00 last year i had the boost bottle power pack and stock pipes and it ran fine
