1999 GMC Yukon SLT
Supercharged 383
4 Door - 4 Wheel Drive
Black exterior with gray leather interior
Alloy wheels
Running boards
140 amp alternator
Heavy Duty cooling system
Heated, power, leather seats
Heated, remote outside mirrors
Inside mirror with temperature, compass, and auto dim
Full dash gauge package
Push button four wheel drive
Towing package with Bilstein/Delco shocks
Weight distributing trailer hitch
Improvements and Upgrades
Engine – Complete performance built 383 cubic inch
New - Dart heads
Stainless steel valves
Valve springs
Rocker arms
Head bolts
Forged Probe pistons .030 overbore
Steel crankshaft 3.75 inch stroke
Cap screw connecting rods
Timing chain and gears
Oil pump
Fuel injectors – converted to multi-port injection
- Block was bored, honed, decked, and line bore checked
- Complete rotating assembly was balanced
- Complete Whipple Super Charger system running 6 lbs. of boost with water injection
- Hyper Tech Power programmer
- Digital Boost and Fuel pressure gauges
- Scan Gauge II engine monitoring system
Rebuilt Rearend
New – Ring and pinion
Carrier bearings
Pinion bearings - seal
Axle bearings – seals
Yukon brand clutch type posi-traction carrier
Rebuilt Front Suspension
New- Upper balljoints
Lower balljoints
Tie rod ends
Idler arm
Front end alignment
New General Grabber AT2 Load range E (10 ply) tires
Rear air assist springs
Digital Transmission Temperature gauge
Electric trailer brake control
Also has newer starter, battery, front brake rotors, and fuel pump
126,000 miles on vehicle
5,000 miles on engine rebuild
3,000 miles on rearend rebuild and tires
10,000 miles on front suspension rebuild
$5000.00 in rebuilding and improvements
Asking $8000 complete as described.
507-437-6277 ask for Daryl after 5pm
or
summitx670156@yahoo.com
I am posting this for my dad who is selling the truck. It is currently located in Austin, MN. I live in Burnsville and could have it up here if you would like to look at it. Contact me or my dad regarding any questions. Thanks
Supercharged 383
Alloy wheels
Running boards
140 amp alternator
New - Dart heads
Valve springs
Rocker arms
Head bolts
Oil pump
Rebuilt Rearend
Carrier bearings
Lower balljoints
Tie rod ends
Idler arm
Front end alignment
or
