1995 500 EFI Fuel Problems
SixtySevenGT
803
116
Middleton, Idaho
I have 2 1995 EFI Sleds. Preaseason check out.
New Battries fully charged
One is apparently not getting any fuel, the other one runs fine
The fuel pump seems to be bolted the bulkhead not in the tank.
I can briefly hear the one run when I turn it on.
The one that does not run no noise. I can put gas in the cylinders and it runs.
Can't belive he fuel pump would fail, they have been bullit proof. Anybody got any exprience with these. Anybody an electric fule pump for one ?
Guess I could try and by pass and see if it runs, lots of wires.
V
volcano buster
1,614
Stayton Oregon
Can you verify that the pickup tube in the tank to the pump is intact?
Can you remove the fuel line after the pump, prime the pump and verify that you are getting adequate flow from the pump?
sno*jet
2,826
1,298
sounds like ya already made a good diagnosis of your problem. can ya swap pumps easily to be sure?
is it the injectors or the pump that make the noise? i know we used to pull ours over one cycle and wait for the injectors to prime (noise), then wham, would fire on first pull every time.
