Looking for a Ford technician and/or guru to help with speedometer problem. Truck is a SRW 4x4 "XL" Standard Cab 5.8 liter gas engine w/ 5-speed manual and 4:10 axle gears.
A couple winters ago, we had a cold snap with below zero weather for a few days. Ended up stuck in the ditch, spun the tires trying to get out. Speedometer stopped working and hasn't worked since. Tried finding a drive cable to transmission tailshaft, figuring there must just be a plastic drive gear on the cable broke. My other gauges for battery, temp, etc. still work. My Chilton manual in one spot illustrates a cable and in the text says my particular model has a speedometer sensor. I didn't want to start yanking on wires on the tranny when I was't sure what to look for.
I have draw in the system somewhere drawing the battery down. I have had to replace the battery twice now, once before this happened and once after and since I didn't drive the truck this last winter due to health issues the current battery got killed again. I also have an issue with the float level sender on one tank of the dual fuel tanks either showing empty all the time or "floating" between empty and about 3/4 full. These are things I'm needing to address as well, but I wanted to start with the speedometer if it was something I could do myself.
If it makes a difference this is a Canadian-built model from the Ontario factory, I've already run into the serpentine fan belt being different than what is shown for my particular GVW in the American versions.
I want to be able to get this running and fixed up, it hasn't been driven hardly at all the last few years because of the price of gas and my family out grew it. My biggest hurdle is trying to convince Momma to let me keep it and have it be my daily driver again :ballchain: out:
Any help is greatly appreciated, thanks in advance!!!
