1982 bravo 250F: chaincase oil drain?
Oct 26, 2012
307
55
Oly
Just got the sled for the kids. Now, doing some maintenance.
Trying to find a drain plug for the chain case oil.
Only thing I have found is that I might have to take the whole cover off to drain it. *sigh*
Is there a drain plug? If so, where?
Thanks!
30
3
8
That is not the drain plug! That bolt is more so level indicator. Once you get your 250 ml or so back in the case, the oil should start to flow out that bolt hole.
Unfortunately you have to make the mess and pull the cover. You can minimize by strategically placing absorbancy under tha affected area.
