19' 3" - convert to TKI
K
klarkkentster
307
77
Bremerton, WA
All -I converted my 19' from chain case to belt. Curious what ratio I would need to get rom TKI to match the 2021 QD2 gearing? I have a 25 tooth on now and on the TKI website it states 2.32.
Teth-Air
4,561
2,790
Calgary AB/Nelson BC
www.specified.ca
63:28 is closest to gearing for QD 2 but you have the chain case and that model has a 58 tooth bottom gear so you will need a 26 top gear. The best choice however is determined by your motor power and track length and lug size. Also altitude you ride and type of riding.
gonehuntnpowder
1,033
566
Eastern Idaho
I am going back and forth. My 16 has the TKI on it geared 25/63 for a 2.52 ratio. Pulling a 174 3 inch track it had a ton of bottom end but doesn’t climb in the longer pulls like my 850 174 does. Not sure how much of that is gearing and how much is engine.
Teth-Air
4,561
2,790
www.specified.ca
You definitely need the 850 or turbo to turn a 174 track fast.
K
klarkkentster
307
77
Bremerton, WA
So the Qd2 is around a 2.25? I started out with a 24 tooth which is 2.42 - switched to a 25 tooth at a 2.32 and pondering a 26 which is 2.23. @4 pulled crazy hard off the bottom. I like how the 25 pulls but lacks top end on long pulls. I have mine completely re-clutched as well. Just wonder how much sand i'll lose going from a 25 to a 26 in the TKI belt drive gearing options.
Teth-Air
4,561
2,790
www.specified.ca
Do you have adjustable clutch weights? You would be better off running that 25 top gear and move some weight to the tip of the clutch weights, if it feels its just not shifting out. This way you more effect only the top end and less suffer on the bottom end.
K
klarkkentster
307
77
Bremerton, WA
I do have adjustable weights and that's a great suggestion the more I think about it. Feels like it hits wall with top end speed
Teth-Air
4,561
2,790
www.specified.ca
So if it is maintaining its RPM but is not shifting this can do the trick. If it is already dropping RPM because it just has no more to give, obviously it will just lose RPM more with more tip weight. A steeper helix would also make it shift out more and load the motor more.
